Alignment Results - OME 861/862
Mukilteo
Today I got an alignment to check Camber/Caster and adjust Toe after recently installing OME 861/862 low lift springs and having the front knuckles, trunion bearings, wheel bearings replaced and repacked.
Here are my Camber/Caster alignment results (Toe is now in spec) with some thoughts/questions. Any input is much appreciated.:D
Camber (spec: 1 deg +/- .75 deg)
Results: LF: 0.1 deg RF: 0.2 deg
Any thoughts why camber is off? Could it somehow be due to the front knuckle service? All new parts were used. I do notice more tire wire on the inside tread.
Caster (spec: 3 deg +/- 1 deg)
Results: LF: 1.0 deg RF: 1.1 deg
I assume caster is off due to the low lift springs, but to be honest I don't notice a change in how the car drove before or after the springs install, except of course the improvement in handling. Caster correction bushings?
The rear camber and toe seem fine, but I have no spec to compare them to:
Camber
Results: LR: -0.3 deg RR: 0.0 deg
Toe
Results: LR: 0.29 deg RR: -0.07 deg
Camber isn't adjustable but is influenced by the rotation of the axle. While you might have bought the low lift springs you have enough loss in caster to warrant the install of OME caster bushings. I think installing those would fix both situations but this isn't that common of an install on here so no guarantees.
I would watch the for sale section for some bushings and put them in. While you might not think the truck needs them I bet you would feel different after their install.
PACNW96;
how much "lift" did you get from those springs over stock, and how did they affect the ride and handling, compared to stock? How many miles on your 80 when you did the swap? Thanks
PACNW96;
I got around 1" to 1.25" lift with the OME 861/862's. There is such a huge improvement over stock I can't begin to explain. No more top heavy feeling when going around corners and under hard braking there is no more embarasing nose dive. The bouncy feeling from the rear is gone. The rig just feels more stable. Definitely worth it and in my opinion OME springs should have been OEM.
I installed the springs in combo with OEM shocks, purchased from Dan, which can handle the slight lift of 1". I had around 100k when I did the install. BTW...use lots of penetrant on those rusty bolts before you start wrenching...
Russell
Thanks for the input Rick. If the OME caster busings could solve the caster and help camber that would be great. The uneven tire wear is starting to be noticeable too.
no surprises then that your caster is low. Caster changes at 1.74*/inch. so at 1.25" you lost a little more than 2*. I think that the bushings will put everything back to factory specs and improve the handling as well.
