Alignment read out?
Van
Camber and caster off spec.
Whats correction i need to do
Thanks
Three things affect camber.
Bad wheel bearings
Bad trunnion bearings
Bent axle
Toe in is easy to adjust.
Caster is affected by:
Bad wheel bearings
Worn out suspension bushings
Worn out or lifted suspension (springs)
Shops are SUPPOSED to confirm wheel bearings are properly adjusted and trunnions (ball joints on other makes) are not loose.
Many shops don't do this in order to force you to pay twice for alignment or to get you to pay them to do the rebuild.
I would go find a qualified shop and have your front axle checked and possibly rebuilt or do it yourself as a rite of passage.
What I'm saying, I don't see a problem. The alignment shops numbers are not specific to yours. If it drives straight run it
I want to update my camber and caster to spec. I dont know how off i am.
Is thrust angle critical, whats the tolerances
Thanks
How does it drive?
The FSM only calls for the toe to be adjustable, if any of the other measurements are off then something is worn out (bearings, bushings, etc..).
