I have a 97 LX450 with a J springs/L shocks lift.
I have both F/R sway bars removed and no caster correction installed (Slee plates sitting in the garage still).
Anyhow, before I installed the lift myself, I had a little bit of a pull to the left side when driving. I decided finally to stop in to a local Big O Tires to see if an alignment would help.
The mechanic adjusted something......test drove it, came back and then brought me out to the truck to ask questions.
Basically he asks where my sway bars are...why I dont have them on. He explains he adjusted the toe, but could not get rid of the pull to the left.
He is saying I don't have to worry about tire wear with this strong pull (let go and in 3 seconds the truck has changed lanes itself).
He also says that the Sway bars will keep everything aligned so I should put them back on.
I'm no alignment expert but I can't understand how an unadjustable bar bolted to the suspension will fix my alignment.
His other comment was that since there is weight in the drivers seat it will pull to that side.
Well...my skinny ass weighs less than most of my passengers....so shouldn't it pull to the right when I have a passenger?
Ok so on a serious note...will sway bars have any effect on my alignment? Is it normal to pull hard to the left or right without swaybars?
Does no caster correction with my lift have anything to do with a pull to either side?
