Alignment Numbers - Feedback Please
Boulder, CO
Here is my print out from an alignment this weekend. I can interpret it pretty well, but I know there are guys here that are alignment "experts".
Anything that sticks out as an issue?
If you are running stock caster bushings you are in luck, a set of OME 2* or better yet a set of 3* blue bushings and you will be in the specified range.
Yeah man, your prior toe readings are out. I bet you were wearing outside front left, inside front?
And yes, they dont have the correct data for the cruiser specs, thats not cool
Cant help on the other stuff, just toe with my .02 knowledge :meh:
Rick- my FSM shows for caster 3* +/- 45', so I gues that is relativley the same as the 2* - 4* you mention.
Rick & Toy - I am supprised that my cast is low, I have the OME low lift plus about a 1" spacer. So I am lifted over stock but not as much as the typical OME med or firm lift. I also have non-winch ARB and dual batteries. I guess maybe for my truck is lifted enough to make it low?
Yes, their numbers are not correct, they say their numbers get updated from Hunter once a year.
I was mostly concerned with Toe-in since that is the only thing that is easily adjustable. I think toe-in is okay now? I was having a hard time comparing their readouts to the FSM.
Toe is good. Very slight toe in and they got it identical side to side.
Caster is a bit low, but as pointed out a set of OME bushings would fix that perfectly if the rig is driving poorly.
Thanks guys, you have confirmed my thoughts, I'm just never sure when it comes to the steering stuff.
What characteristics of driving poorly might I notice with the caster being low?
