Alignment Issues
I just bought a 91 and the front tires look like they wear heavily on the outside of the tires. The rears look like they have 80% tread left on them, but the fronts have 80% on the inside and 20% on the outside.
The ride is smooth and perfectly straight when I let go of the steering wheel. Is this a known problem with TLC's? What is the likely cause? Camber issues? Thanks
Being new to me, these tires could have even some off another car...
My first check would be toe, too much toe in would cause your issue and it's easy to check and adjust.
DesertMaster came by yesterday to have his tie rod replaced after I examined it a few weeks ago.
Both TREs were shot and he had the same wear pattern on his tires and a pull to the right.
After the tie rod was replaced and a tape measure alignment done, everything seems fine.
wait... tape measure align?
how is this done.. is it in the tech faq?
justinColorado
94-type80 NewGuy
It's done with a tape measure. I'm not sure if it's in the FAQ or not. If not I could write up something tomorrow.
Basically you mark each tire with a "+" and measure the distance between the two marks when they are both facing forward and then again facing rearward.
You adjust the tierod so the distance when facing forward is 1/16th to 1/8th of an inch less then when facing rearward.
You use the "-" of the "+" mark to make sure the marks are level with the center of the hub when measuring.
justinColorado
94-type80 NewGuy
Toe is the only "simple" adjustment on straight axle Toyotas, most of the time it's the only thing adjusted in a "box store" wheel alignment. DYI alignment is simple on a straight axle and has been done by cruiser heads in their driveways for years, I will bet a quick search of the FJ40 forum for "toe adjustment" will net several good threads on the subject.:D
