alignment after axle rebuild?
Sarasota, FL
when replacing axle seal / rebuilding knuckles, do you need to get an alignment once everything is back together? I will be rebuiding both knuckles and swapping birfs from side to side. Would it make a difference if you did or did not disconnect the tie rods from the lower control arm on the knuckle?
Alignment not necessary for axle maintenance as nothing changes. Messing with tie rods, tie rod ends the toe setting can be changed which is the only setting that can be adjusted during alignment. If the tires are wearing evenly and no pulling to one side or the other then no alignment necessary. Add a lift then caster will be changed and corrected by other means.
That is what I figured, but just to confirm, separating the tie rod from the lower control arm on the knuckle shouldn't impact the alignment. Thanks.
