- Joined
- Mar 10, 2007
- Threads
- 62
- Messages
- 1,108
- Year
- 1986
- Vehicle Model
- 60 Series
- Mileage
- 269000
- Color
- Beige
1986 Toyota Land Cruiser FJ60 owned since 2007. $16,000. Rebuilt 2F with new 0.02" over pistons, and a Delta camshaft. The head was rebuilt to accept larger SBC valves and springs. Very little body rust. One small spot on the cowl and one pinhole in the roof gutter. Frame is in excellent condition. A section of one rear quarter panel was replaced with a donor cutout when the truck was repainted. The previous owner installed an aftermarket sunroof and removed the headliner. I also have the original block and a donor roof section to replace the sunroof if interested. The A/C works, measured 35°F at the vent, although the fan is stuck on low speed. Driver's seat bottom has the usual wear. I have a collection of many spare parts available to the buyer as well. Has late model crossmember to fit a 5 speed without modification. In general this truck has had no modifications and only OEM/original parts were used.
Everything works in the truck except the fan speed adjustment and I daily drive it when the weather is good.
Other services include:
- Complete front axle service done less than 500 miles ago with OEM/Koyo parts.
- New front rotors with rebuilt calipers and Advics (Aisin) pads.
- Rear differential was replaced around the time of engine rebuild with a used unit front differential (only 4wd miles).
- JimC recurved distributor
- Has an FJ62 rear sway bar using the existing factory hardware/mounting points.
- Brand new OEM cat-back muffler installed
- New OEM wheel studs
- New windshield wipers
- New fuel/oil/air filters
- All fluids changed <500 miles ago
- New alternator
- New OEM windshield washer reservoir
- New OEM battery tray
- New OEM hatch struts
- New OEM clutch master cylinder
- New dry-cell battery
