Alarm won't reprogram auto-lock
Canyon Lake, TX
I have tried to reprogram the auto-lock function many times now but have not had any luck. I am using the instructions off of Slee's site. I can get the alarm light to come on after the 5 on-off cycles but opening and closing the door per instructions will not turn off the auto-lock. After the 30 seconds my alarm light does go off like it should. Thanks for any help you can give me.
Are you certain you have the RS3000 alarm?
-B-
Good Question. Hell, I don't know. How would I determine what I have?
Hell, maybe you need to research which Hell alarm you have Hell.
-B-
When I followed the instructions off of Slee's site, the system came on like they said it would. I "assumed" that I was on the right track with Slee's instructions. Are you saying that there are other alarm systems out there in 97 fzj 80s that behave as earlier stated? If so, how do I determine which one I have?
Since you live in Texas, that might be a GST vehicle. They had several different alarms over the years.
Take a picture of the dash LED and the key fob. I might be able to tell from that. The instructions on the Slee site are early versions of the manuals on my site. Christo graciously offered to host them a long time ago because my web hosting site did not provide for large files at that time. He is hosting the RS3000 manuals (I know his link says RS3500 or something.... but they are the RS3000 manuals.)
I have some of the GST alarm manuals too but I haven't loaded them to the web site yet.
If you have the RS3000 alarm, then it is important to follow the instructions precisely.
No deviations.
No "Well, I thought..."
No "This should still work..."
Do the procedure exactly as stated in the manual.
-B-
This is the only key fob I was given by the P.O. I'm guessing it is a replacement of some kind and not the original. Hope it helps.
If a picture is attached to this post , at least you have given me a good excuse to finally learn how to use my computer and post a picture. :cheers:
Interesting.
That appears to be the RS3000 glass breakage sensor and LED but that is not the "correct" fob. The fob may work and you have implied that some features seem to work. If it were me, I would try to find someone with a real RS3000 fob and see if you can get it to work properly on your truck. FYI, Dan can still get them from his Toyota sources.
If it works, then you know you have a working RS3000 system and just need to get the fob.
If it does not work, then you need to get a picture of the device under the driver seat. Also get the FCC number and anything else that will help identify the box.
-B-
If in fact I have the rs3000 system, is the correct fob required to change the auto-lock feature/programming? Or are there instructions like the rs3500 that will change its programming without the fob?
MMMM..... I have the sinking feeling that you are going to say that the improvement from the 3000 to the 3500 is the ability the change the programming without the fob. :doh:
I have not read the instructions for several years. I had to get them because, like you, I did not like the auto-lock feature that was enabled on the RS3000 in my truck. I do not believe you have the RS3500 alarm (if there is such a beast.)
Read post #6 carefully.
Regarding reprogramming the auto-lock... I followed the instructions in the manual and it worked for me. I do not remember if I had to use the fob or not. If you have followed the instructions and it does not work and it does not use the fob for the programming then find out which alarm you have. Removing the driver seat takes about 3 minutes. Four 14mm bolts and 1 electrical connector. I have done it about 10 times and it doesn't get much easier.
You may be able to get the information without removing the seat by looking at the black box... try pulling the seat all the way forward.
-B-
Thanks for all the help you have given me. I'll get that seat up and take a look at the box in the next day or so. :D
Well, I finally found the alarm box. It was under the carpet just in front of the driver's seat. It is a RS3000 (08190-00921) It has a little reset button on the side.
I also found a small switch on my lower DS foot panel. The little toggle switch is broken so the only way I can move it will be to short the wires together. If this stange little switch is insignifigant, forgive me for mentioning it but I was told that some toyota alarms use a switch like the one I found for their alarm funtion.
I'm going to guess that I have been using the correct instructions from Slee's/ Beowolf's site and that the alarm is somehow broken. Does the broken toggle switch play in to the reprogramming or am I doomed to live with the auto-lock feature for the rest of my days?
What if I unplug the alarm box completely? Will the truck still run with no problems?
On a positive note, I did take all the carpet out and completely wash it out at the car wash. Looks like the PO had spill no less than 2 Super Big Glups around the middle seats.
As far as I know, that switch is *not* part of the normal RS3000 alarm installation. One of the manuals on my site is the alarm installation manual. Review it carefully and I believe you will find that there is no toggle switch that is part of the normal installation. You need to trace the wires to see what that switch is doing.
Other than the inability to turn off the auto-lock, does your alarm seem to function normally?
-B-
I have never tried to use the alarm. It beeps 5 times when I shut the truck off and it of course locks my doors for me but other than that, I never use it or know it's there. I also do not use my FOB.
I did mess with the small switch. It seems to be a momentary switch/ normally off and when I shorted it, the red LED next to the gear shifter would light up and I could hear a relay activating. I tried the lock programming instructions with the light on and off with no results.
I also unplugged the little black box completely to see if the truck would run without it. The starter would not engage, but the door locks still activated automaticly as if the alarm was plugged in when I turned the key to run. This made me think that there must be some other device in the car that is telling the locks to activate. At this point in the day, I decided to put the carpet/seats back in and proceed to step #6 :beer:.
My next move is to track down the origin of the switch wires. Maybe there is an aftermarket alarm lurking under the dash somewhere? Considering the mass of high end stereo wires I found left under the carpet from the PO, my guess is I'm dealing with some "creative" workmanship. :rolleyes:
We have reached the end of my ability to assist. That switch is not part of the alarm system. The alarm system seems to be "needed" in that you cannot simply unplug the black box, but the alarm system is not being used by you. I fear you are breaking new ground here and you will have to lead us to any further assistance.
On another note... I was at Canyon Lake last week while on vacation. We may retire to that part of the country and wanted to check it out. Marble Falls got slammed and they were still cleaning up while we were there. Do you live on the lake?
-B-
No, I don't. But I do live close enough to hear the bigger boats running up and down the lake though. I'm on the north side.
If you like water sports, it is a great place to be. Fishing's good, tubing down the Guadalupe is fun, and it's a great place to road bike with all the hills and country roads. Your also only 4hrs from driving on the beach.
The weather is a little tough, but if you can get use to it, it works in your favor because the lightwieghts get chased back inside to the A/C and that leaves the rest of the place fairly empty during the week. The weekends are usually more crowded due to all the people from San Antonio coming up to enjoy the lake.
Thanks for your help. Next time your are in the area, let me know and I will buy you a :beer:. :flipoff2:
Finally figured it out. I traced the small switch to an after-market alarm system stuck up under the dash. I unplugged it and the locks no longer activate when the truck is turned on. :)
Lesson learned : Don't under-estimate the P.O.'s ability to screw up a good car.
Thanks again for all the help.
