Aisin carb question...
Bay Area California
When the choke is resting should the valve be closed? Also, need an assist on an adjust to my main metal choke line so that it has play because it’s sticking ...
Thx
I’m not sure what you mean by “resting” but when the choke knob is pushed in all the way, the choke valve in the air horn should be vertical or all the way open. The FSM page you posted refers to the setting of the choke breaker which kicks the choke open partially when it is all the way closed. You pull the knob all the way out, which should close the choke valve. Then you push in the choke breaker rod and measure the angle, which should be 38 degrees from vertical. You djust the angle by bending the rod.
To lubricate the choke cable, clean it first with brake cleaner spray and then lube it with a dry type cable lube, like DrySlide graphite or teflon lube. Remove it from the carb and elevate the free end so that the lube will run back toward the knob.
Sorry resting meaning not engaged...thanks for that ... I was asking because I had pushed it in and nothing had happened .. but it was because that metal choke line was stuck ... that arm that extends up to support the cable to make that left turn towards the carb was making it stick.. I had to loosen that screw a tad and play with it a bunch but I got it functioning properly . Still isn’t “easy” to push in choke
One more thing - I’m missing a throttle positioner arm on the back of my carb... now I’m seeing this C-clip attached are the front... am I missing something here too!? The angle of the FSM and Haynes doesn’t give me an idea of what’s supposed to be here if anything ... see pic..
The screwdriver is pointing to the end of the primary throttle shaft and it has its proper washer and C clip installed. Later years have an extended shaft and some other linkages at this position, which may be the source of your confusion.
The throttle positioner isn’t necessary. It is there to prevent backfiring out the exhaust during engine braking.
My MAN ! Pin_Head is on the Targets and On the Mission !
Thanks for your Valued Input & Expertise here Brother .................
matt :)
@Kschep is a Friend of mine , and any solid constructive help is greatfull
