I tried to post on another thread about the same thing but the thread was closed.
I drained my battery completely. I charged it and everything is good but the airbag light is on.
The other thread was exactly the same.
The procedure to reset was as follows posted by another mudder:
Airbag reset:
Go to DTC in engine bay. Small black box on pass side near firewall.
Put one wire in Tc
Put one wire in AB
Put ignition to on.
Touch
Tc to ground 1 sec
AB to ground 1 sec
Tc to ground 1 sec
AB to ground 1 sec
Tc to ground 5 sec
That should do it. Hope that's clear. You need to do them kinda fast. If it don't work keep trying. I had to try several times to get it right. But it works.
I found the DTC and identified Tc and AB but can't get it to work. When it says Tc to ground, does that mean just touuch it to a bolt or something to ground it or is one of the spots in the DTC the ground. Also, I've been trying to do it by myself, maybe I need someone to switch the ignition to "on" for me so I can be a little quicker to run the sequence.
Airbag reset:
Put one wire in Tc
Put one wire in AB
Put ignition to on.
Touch
Tc to ground 1 sec
AB to ground 1 sec
Tc to ground 1 sec
AB to ground 1 sec
Tc to ground 5 sec
