This solenoid will be used to run an ARB air locker. I do not want to buy an ARB solenoid, as this setup is going to be run with all NPT threads, no BSPT. I also want to keep parts easily available.
I found a solenoid at Mcmaster-Carr that I believe will work- I'm asking here to check before I order, as it is not cheap.
It is a three-way, single solenoid. Closed by spring pressure when not activated. Good for the pressure necessary for the ARB. 12VDC. 1/8" NPT
It is available in both 2 and 3 port configurations.
^ This is what I am not sure about. The ARB solenoid exhausts to atmosphere when closed, thus causing the locker to disengage.
The cataloge reads
It would seem to me that the two port configuration is what I want, that the 3 port is made to exhaust back into the system, whereas the 2 port exhaust directly to atmosphere like the ARB solenoid.
Thanks for any clarification. I am not well versed in industrial parts and engineering.
The cataloge reads
"3-way valves are most often used for single-acting air cylinders. 3-way valves with 2 ports exhaust directly to the atmosphere."
