Air Con controller weirdness
Hi, I bought 1993 ex Jap 1HD-T truck about 6 months ago. When I bought it the aircon was faulty and the guy said it needed re-gassing, which he got done for me as part of the deal. The aircon works but has some strange behaviour:
It intermittently stops working for no real reason. Usually its after I've been driving for about half an hour. The fan and everything keeps going but it stops cooling. I noticed that when I move the temperature control slider knob-thingy from cold to hot that the unit cycles from left to right through the different air inlets ie. Controller hard left to cold turns on the left most air inlets which is top vents to driver. Move it a little to the right and the body and leg vents come on, move it a little further and it moves to the leg vents only. Its weird..seems the vent selection follows the temperature controller position.
Seems to me there is an electrical controller that is screwed or been wired up wrong. Before I pull the dash off to look for a controller has anyone any suggestions, and advice about how to go about diagnosing and fixing this?
TIA
Does it have the auto button? If it does, it's normal. Just hit auto, set it to the temp you want, and forget it.
Didnt want to drag up an old thread but this description is exactly what I am experiencing. A/C blows real cold for 20-30 mins then nothing. PO thought it was just needing recharged but since it blows real cold to begin with I doubt a lack of refrigerant is the problem. I don't have an auto button but I notice that when I turn on the A/C the engine revs very erratically - can be as high as 1800rpm then drop to 450rpm.
Any suggestions?
Can you put a temp gauge on it. I have a issues to but I do think think they are related to ac issues I think something is going on I the coolant system.
Mine shuts off every time at 226 or so degrees. Which is what I believe the ect tells it to do when the motor is getting hot.
That's an interesting thought but my temp gauge never goes above the half way mark. I have an infrared thermometer so will take a temp reading tomorrow just to be sure.
Yesterday I had an opportunity to check temps etc as described. I first checked that the A/C was working then I took her our for a drive to get her warned up. Drive for about 6 miles during which the A/C continued to work. I measured the temp at the theromsat at it was 197°F.
Later in the day I had to drive up to LA - mostly freeway - I noticed after an hour that the A/C was super cold. I happened to have the IR temp Gauge next to me and so I measured the tempnout of the vents. It was 25°f. Shortly afterwards the A/C stopped working. Not sure why the temp would drop so low. I had measured the vent temp earlier in the day and it was 43°f (about right).
Any ideas?
