Air Compressor Pump?
Boise ID
I am tired of my oil-less compressor. It is a 22 gal, 0 hp, can't keep up peice. I am thinking about getting a pump and 220v motor and using the existing tank. Anyone do a conversion like this?
I want something that will run autobody tools so it needs to be at least 10 to 14 CFM at 90 psi.
Edit: not really cruiser tech, but where should I post it
Outfitting is the proper forum.
If you want to do something cheap, you could rig up one or two York auto A/C compressors. They are internally oiled, there is a 10cfm model, and they are cheap. (I have two-total cost $0) I can run an impact wrench off mine with no tank with the engine at about 1000 rpms.
I'm pretty sure Ingersoll-Rand will sell compressors alone. Cast Iron 100% duty cycle oiled. Hard to beat.
Have you looked into a used compressor?
Around here machine shops/ auto shops will have an auction when they close. Could get some huge industrial stuff at a good price.
That compressor would be sweet, (I have a smaller 120v version).
The yorks are good to up around 300 psi. I have exploded a hose with one by accident. Not sure what the CFM rating is that high.
