Air canisters
New Mexico
wondering if I can remover the exhaust tubes, vacuum valve assembly, and replace canister with plain canister?
Depends on your local emissions laws. If you never need to pass an inspection then you can eliminate the PAIR system.
You can also get a heater hard line and throttle cable bracket from an obd2 truck (1995-1997) and eliminate the PAIR valve completely. Put caps on the vacuum lines of course. If you delete the VSV for PAIR, that might cause a CEL.
You can move the o2 sensors into the ports where the air injection used to be.
Toyota sells blockoff plates that will delete the unused ports. They are for a van - I forget the part number. Search here for pair delete and you will find a part number.
I don't actually know if the 3FE air cleaner lid will mate up with the 1FZ-FE VAF meter.
