Got it!!!
Hi All. Quick update.
I was able to read the SRS DTC codes, here's the procedure:
1) Turn ignition to on or acc for 20 seconds
2) Using SST (paperclip) jump terminals Tc and E1 of the diagnostic connector (DLC1)
3) Read code(s) by counting flashes of abs light (while ignoring all the other flashing lights)
Codes are gathered by counting flashes, 1.5 seconds between digits, 4 seconds between individual codes. If you miss it, keep waiting, it will cycle again.
Mine was a 54 (Open in P squib circuit) which corresponds to the passenger airbag being disconnected.
I reset the codes and all is well.
Incidentally, the reset Darwood posted works. However it doesn't work if the wires you are using do not have contiuity (
). I checked my "reset" SST with my multimeter and found that I had a break in my wires. Fixed it and was able to reset it.
Briefly, for the archive:
1) Get two separate longish wires (another SST!)
2) At the DTC put one wire in the Tc terminal and one in the AB terminal
3) Turn the ignition to on or acc for 6 seconds (leave it in on or acc)
4) Go to the wires in the DTC and do the following
a) Tc to ground for 1 second, remove
b) AB to ground for 1 second, remove
c) Tc to ground for 1 second, remove
d) AB to ground for 1 second, remove
e) Tc to ground for several seconds (5 according to the FSM)
5) ABS light should flash rapidly and reset
That reset the codes.
Note, as Darwood says, you need to switch the wires quicky (.2 seconds?) but that is easy to do.
By the time I got to the drivers side my ABS light was off.
Also, make sure your SST (wires) have continuity or this won't work.
The dealer wanted $35 just to read the codes. Then they couldn't
find the "special connector" anywhere. I should've loaned them my paperclip
Glad I tried again. Thanks everyone!!!!
Good luck.
Charlie
