My AHC is stuck in low and if you try to raise the truck, it gives up and flashes the "OFF" light for the AHC.
132k miles. AHC fluid flushed at 80k miles. Ironically, I have two new cans because I was just about to do it again!
Nothing comes up when scanning the ECU - I am guessing the AHC system runs off a different ECU...? Meaning I would have to pay Lexus to diagnose the system...? Nearest dealer is 550 miles away.
Is there any way I can test the system at home to determine the problem? I tried resetting the ECU to no avail. The pump is running, I can hear it, feel it, and it is getting hot as I try to make it raise the vehicle. The fluid is not moving and the height is not changing. The truck rides like crap when stuck in LOW mode. The AHC fuses are intact.
I DID search and there are many AHC threads, mostly telling people how to flush the system. I cannot even do a flush, as I cannot get the vehicle to raise. I would like to know if I require an expensive fix, because if so, I may opt to just scrap the AHC and buy some regular struts.
Suggestions?
Suggestions?
