I think I've found a solution to the problem of the rear sensor reading being - 11 mm . The AHC control unit has three groups of height sensor values. They are all listed in the TechStream software in the lower right corner. The altitude sensor values that everyone is guided by (in the upper left corner of the program) are provided with corrections. The adjustment values are shown in the "FL, FR, RR Height Adjust" lines. The correct values of the altitude sensors (without adding correction) are given in the lines "FL, FR, RR After Height Adjust". It says that the altitude sensors need to be adjusted using these lines ("FL, FR, RR After Height Adjust"). I don't know why the AHC unit has these adjustments, what they're for, or how to remove them.
