Is it possible to lift the rear of a LC with AHC by 1/2"? Just looks like the stock settings make the truck look like it's sagging slightly in the rear.
Thanks guys
Thanks guys
Yes, simple job to reposition rear, or front, sensors to adjust height. Attached is an LX height sensor adjustment procedure, the "to ground" dimensions are the same for an LC. If you don't feel like crawling around to measure the "to ground" dimensions then 19.75/20.5 hub center to fender is sufficiently accurate. The standard approach is: check/correct front side to side level; check and adjust, if necessary, front and rear neutral heights via the sensors and lastly adjust pressures to the neutral height via torsion bars and new coils/spacers if necessary. You need Techstream (or a gauge set) to do your pressures and read height sensor displacement feedback.Is it possible to lift the rear of a LC with AHC by 1/2"? Just looks like the stock settings make the truck look like it's sagging slightly in the rear.
Thanks guys
