Just bought a electric aftermarket temp gauge as my original has carked it, my question is can I use the oem sender as the threads seem to be different.
BJ
BJ
Likewise, the 2F cylinder head has three holes for either "unions" or "plugs" in the water jacket. The temperature sender screws into one of the unions, and the heater supply or return plumbing plugs into the other. The third hole is usually just plugged. Removing the plug leaves a space for the aftermarket water temp sender or sensor.dgangle said: Not sure about the diesel LC's but SBC have multiple places to locate water temp sending units.
You said that your aftermarket kit is electronic. Your OEM sender will probably not be accurate unless it has the same ground characteristics and resistance curve as the aftermaket one. It probably doesn't.bj42turbo said: my question is can I use the oem sender as the threads seem to be different.
Mr. Toad said:Likewise, the 2F cylinder head has three holes for either "unions" or "plugs" in the water jacket. The temperature sender screws into one of the unions, and the heater supply or return plumbing plugs into the other. The third hole is usually just plugged. Removing the plug leaves a space for the aftermarket water temp sender or sensor.
The stock sender (and the union it screws into) are probably BSPT threaded. You should be ably to buy an adapter for your (most likely) NPT sender. My Sunpro mechanical gauge kit came with one.
