At its most basic level, this is the principle to how AHC works to support a load. My numbers are made up for the sake of discussion.
For an unladen LX, the hydraulic globes via the hydraulic piston (where the shocks would be located) and coil springs share the load to support the vehicle. Something like 50%/50%.
For the rated 1300lb payload of the LX, here's how the load is supported at neutral height:
650lbs on hydraulic globes
650lbs on coil spring
Increase the spring rate (e.g. violet springs) or preload of the coil spring and now:
1000lbs on coil spring
Now the suspension will support 1650lbs at neutral height. AHC self adjusts damping to match as the system is dynamic.
