after rebuild idle control
Rio Rancho, NM
Hey folks since I rebuilt my 94 1fz
It idles high in Park and Neutral after being in gear.
During first start up idles normal just under 900 ish. Drive it and put in park goes up to around 1500RPM. Put in reverse or drive the RPMs go down. I thought the computer would adjust as it went but I'm at 1400 miles and still does it.
I adjusted the idle some and it seems fine in garage until I drive and then....it goes up. Any ideas on why it does this and what I need to look at for further adjustment.
Timing was set and like I said idles fine at start.
Investigate your IAC.
I had an extra tb assembly(with iac and other sensor) so I cleaned it and threw it in. It idles way better. I think you were spot on baldilocks.
Thanks again.
Shifts out of park and drive better as well!
Thanks again.
Baha I get lucky sometimes. Glad you are back on the road.
