Advice Requested on Compression Readings
Southeastern Virginia
Greetings. My 1995 FZJ80 IFZFE with 167,00 miles (HG done at 110,000) was in for a compression test at a Toyota dealer in Wisconsin this week. The tech knows Land Cruisers. He reported the following results today:
Cylinder 1: 140 psi
Cylinder 2: 160 psi
Cylinder 3: 160 psi
Cylinder 4: 160 psi
Cylinder 5: 160 psi
Cylinder 6: 155 psi
I'm obviously quite concerned with the low reading on Cylinder 1. The truck runs very smooth and idles great. I'm confident the tech performed the test to specs. Minor white exhaust on start-up, but clears real quick. Shifts great and runs at speed very well.
I've read the threads on this issue and there are a variety of responses. I'm hoping for a response specific to my truck's history/situation/plans - i.e., I'm the second owner (purchased from a soccer mom in 1999; she never drove off road); I have traveled with it throughout Africa and Latin America (hard driving); I have over $6,000 in recent major refurbishments (from the entire exhaust to a new fuel system); I have plans to start using it for expedition travel in North America in retirement (circa 2019-20).
I thus want to avoid the catastrophic failures and will jump into an engine overhaul if needed. This is basically what the tech is suggesting (go figure) and is unfortunately well beyond my mechanical abilities.
Many thanks for any advice or suggestions.
CC
FYI - I found this pulled from the FSM on one of the posts addressing cylinder compression (I'm obviously well beyond the min 14 psi difference between each cylinder but above the 128 psi min pressure on Cylinder 1):
Attached is my most recent Blackstone report. Hopefully this will provide a snapshot of the engine's overall health. Don't know if it will help with any advice on my Cylinder 1 compression issue though. Throwing it out there. Thanks much.
(FYI - I'm meeting with the tech on 11 June 15, so any suggestions this evening would be great.)
Not an expert on this. I think mine were both quite a bit higher and closer (much lower mileage though), but I'm thinking that 20 psi instead of 14 is not the end of the world and maybe not enough of a reason for an immediate complete overhaul or worries about catastrophic failure. What makes you think it'll fail suddenly? Maybe wait and keep an eye on it? Not very hard to do the compression tests yourself, say every 6 months or so if worried? Easy enough to do a leakdown test at the same time when you're in there. You still have 4 years before you'll be on the road, sounds like.
Thanks - that's exactly the kind of advice I was looking for. I'll bring that up with them tomorrow - monitor it every six months. I know I could test it myself so I'll look into that as well. My worry about catastrophic failure stems from OCD - wanting to make a 20 year old truck perfect isn't realistic and drives my wife nuts. I need to remind myself that these are solid motors and take your advice. Thanks much.
Did the tech do the spoonful of oil trick?
That is when one cylinder reads low put a tablespoonful of oil into it through the sparkplug hole and quickly test again. If compression remains low then it is valve/valve seat whereas if compression comes up to the other cylinders then it is piston rings.
if I got those #'s I would just run it. If it drives great then forget it. Keep an eye on it and save some $ for an eventual top end rebuild. If you want to go the extra mile get a "wet test" done (spoon test the other poster mentioned) to see if it is the rings. Most likely if the engine has been taken care of it is the valves that are causing a lower compression and this is easily remedied by having the top end rebuilt and a new headgasket.
if I were a betting man I would guess that the lower psi valves are partially burnt. In my experience most of the lower end of these straight six engines are bulletproof and are hard to kill. I have not seen too many with bad rings and pistons, usually it is the top end that needs refreshing.
My 80 has 200k and I recently redid a top end rebuild and it runs great now. The lower end showed very little wear.
Thanks for the replies. I met with the tech this morning and he gave me exactly the same advice - monitor the lower pressure in Cylinder 1, but no need to take action right now. He didn't think this would develop into a catastrophic issue, especially since all pressures rose when warm.
The service manager had been the one to suggest that I may need a rebuild - guess he was being cautious. Overall, this was good news from both the Forum and the Toyota tech. The truck runs great at idle and at speed; the white smoke I mentioned is normal exhaust on a cold morning - definitely not the sign of a leak; the HG was done about 70K ago, but I will continue to monitor it; everything else related to engine performance tested fine.
Bottom line - I feel a lot better abut this issue and will simply monitor performance over the coming years. As the tech said, it could have been running low since the HG job, which was in 2002, and I just never knew about it. This was the first compression test I've had done since that repair.
Question - how often would the Forum recommend a compression test? I appreciated e9999's suggestion of every 6 months and will look into doing that myself.
Separately, we found that the only piece of rust on my truck was the PHH. The pipe looks like part of a shipwrecked freighter from the 1930s. The tech is doing the bypass for about $110.00. I know I could probably tackle this myself with all the threads on Mud, but figured since it's already with the tech for some wheel bearing work I'd just pull the trigger. Seems like a very fair price for parts & labor.
Thanks again for the advice. It's great to have unbiased tips and support out there.
the service manager likely wan't being cautious, just doing is job of milking the customer as much as possible...
the metal pipe going up? I don't recall ever reading about that one rusting...
If it runs well with decent power, you would be doing an engine rebuild to satisfy a number. I would not do that. You have no idea if the tech's compression tester has been calibrated in the last decade. Drive on and enjoy. You can always rebuild it later, but honestly never get it tested again unless you have symptoms, or it will just make you crazy.
Thanks e9999 & 1973Guppie. Regarding your question, yes, it was the metal pipe running vertically along the firewall. It was completely rusted and bound to fail at some point. The tech is doing the bypass and will cap that pipe as best he can. I thought $110 was fair.
Regarding the service manager & cylinder issue, I know the type that try to gouge us. I think in this case, though, he just didn't have the experience that the tech has and was not involved in diagnosing the truck - he heard low pressure and assumed the worst. I think as someone mentioned on this forum, our vehicles are now 20-25 years old, meaning many of the U.S. Toyota techs originally familiar with the 80 are near the end of their careers. I'm probably being naïve, but I'll give them the benefit of the doubt this time.
Thanks again to the Forum for stepping up. I felt a lot better going in there with unbiased advice.
... Question - how often would the Forum recommend a compression test? I appreciated e9999's suggestion of every 6 months and will look into doing that myself. ...
Why would you bother? We rarely use the compression tester, unless looking for a problem, or evaluating a non running motor to install, etc, it stays in the tool box. I know for a fact that it has never been used on mine in the 130K mi that it has been my DD and wheeler.
They are a good indicator, but can be more art than science, the readings need good interpretation. I'll bet if everyone here did a test, very few would be perfect, even on rigs that run and perform well. Lots of things come into play, altitude, weather, cranking voltage/speed, throttle open or closed, how was it driven just prior to the test, etc. For all we know there was a fleck of carbon stuck in the works at the moment that the test was done and that blew out with a quick highway run?
Bottom line, if it running well, smooth, why worry about it?
Cruiserdrew & Tools R Us - thanks for bringing me down to earth. Doing the tests will just drive me crazy. Plus, opening up a fine running engine will no doubt risk other issues while chasing a number. As you said Cruiserdrew, rebuilding an engine to satisfy a number does not make sense. Thanks to both of you. It's running well, smooth and strong - no worries.
