Advice on choosing between GX460s
I would take the lower mileage 2018 base - especially if it's being sold CPO. My use case is pretty similar to yours. The only thing I like about the Lux model is that I think it has power-folding rear seats. I believe there's a way to tap into that power to reliably power a portable fridge. The rear outlet in at least the 2017 Premium, which is what I have, is woefully inadequate.
200k is up there and I think you'd have to expect shorter remaining life with things like gaskets, seals, and anything rubber. The parts themselves are probably cheap, but if you don't or can't do the work yourself it could get expensive.
My brother has a 470 and the airbags blew out on a camping trip. I think it had a little over 200k miles when they popped. He got it used for a good price at the time. He's not the type to do anything more than his own oil changes and early on he's had to replace CV axle because of torn boots, a transfer case seal on the actuator or something like that, probably some more things I'm forgetting, and now the most recent thing is a rear axle seal.
Thanks. Lower mileage / newer is the most common theme I’ve heard, and totally makes sense. I’m going to take that advice, hopefully on the 2018 if the PPI checks out. It’s not a CPO this time around, but was when sold last time.
  • Like
Reactions: r2m
Thanks. Is the 60k coolant advice because of the recent head gasket concerns, or something else I should know about?
Yes, Car Care Nut goes over this on his YouTube channel. Lower the miles the more control you have over the long term maintenance of the vehicle. These are know as soccer mom cars. Folks that generally drive them the first 50-100k and trade them in. They may not have all the suggested maintanence completed if they know they will be trading it in or are oblivious to the maintenance scheule as well.
