Advanced Adapters Pilot Bushing
Long Island, NY
I wanted to spell the title out so that future searches would pick up on it.
I did a search and did not glean to much other than most don't use it.
In installing an SM465 to my stock 2F, I noticed that when I pulled my stock pilot bearing it slid onto the sm465 just fine.
Why not use just the stock pilot bearing? Or, is that what AA intends, so they supply this bushing to go on the shaft and pick up the difference?
They don't really say what to do with this bushign other than soak it in oil.
Is the bearing you guys swap out for "thicker" and just serve the same purpose as putting that bushing in there?
I'd assume so....
thanks for the clarification...
ragman
The issue is that the imput shaft of the 465 is about 3/8 inch shorter thanthe Toyota input shaft. The GM shaft is too short to engage the OEM pilot bearing. The AA bushing is longer to support the GM shaft. I prefer to use a ball bearing that has an inner race that is 3/8 inch longer than the OEM bearing. Someone posted the BCA number for this bearing, so you should be able to find it with a search. Classic Cruisers also sells this bearing.
do a search under treeroot's username. He posted the BCA # in one of his threads.
This works for the stock 6, what about a V8 using the same 4 speed set up? Advanced sends a brass bushing. I also think a bearing would be the best. Sorry for stealing the thread, but I thought it was related.
Thanks in advance.
"The new pilot bearing has a longer inner sleeve to support the input shaft of the SM465. The input shaft is approximately 1/4" shorter. I bought mine from A&W Bearing Supply ,800-535-9638. Part number BCA 202RRE."
Its like $5 if I remeber correctly.
