Adjusting the head light - no work
Albany, NY
Adjusting the headlights - no worky
All I can see is one adjusting screw and that one does not do much if I turn it. Neithe my DS nor my PS seems to adjusting anyting.
More specifically, I need to adjust my DS headlight to the left.
Any advise on how to do it?
I would guess your mounting tabs on your headlight housing are broken, if they dont seem to move when you adjust with the screws. When I bought my truck, I tried to adjust them, and nothing. Found out the tabs were broken, go figure.
Broken tabs are a real possibility, as mine are plastic.
However, when I had to replace a headlight recently it looked like it was not adjusting for a long time, then finally I got all the slack out of it and it adjusted fine.
Be sure you are running the adjusting screw to the end of the adjustment if the tab is not broken.
Hope yours is that easy.
Jack Nichols
1993 LC
I found the screw that adjust the lights left and right. I was able to adjust the the DS and pointed it more to the left. If was pointing toward the middle and drove me crazy for a long time.
Now I have much wider light pattern. So I am good for now. The up and down is not working very well but that was not much of a problem to begin with.
I can see the the adjusting bolt is guided by a plastic tab which is not broken.
One bolt (forget which side) is on it. the the other adjuster, the plastic tab is in the middle of the adjuster.
If the adjusting is the adjuster head hook to that plastic tab, it is not doing anything because it is so far from the adjuster head.
I suppose I should take a picture.
