adjusting brake push rod
what is the proper method? Do you adjust the outer push rod (on that hits the mc). then set the inside push rod? is it okay to push the inside rod in to get it to line up with the pedal? or should it be at its fully extended length? thanks!
i can't figure out how to adjust the booster to mc rod! i see that its threaded at the end and what looks like two nuts to lock it down. I am gonna feaking mar up the rod if i put anymore pressure on it to break those nuts free. am i missing anything here.
The adjustment of the booster rod is critical and if it is too long, it will lock up your brakes. Are you sure it needs adjusting? If so, you put two wrenches on the two nuts. The rod at the pedal is less critical, but if it is too long it will always apply pressure to the brakes. The FSM covers this in detail and I don't have easy access to it now.
it
i got the rod adjusted but the it doesn't really lock down, but it takes some pressure of holding the nut and turning the acorn head to adjust so i guess it won't spin during operation.
