Adding stock lockers to my '95
Ipswich, MA, North Dakota, Phoenix
I've read a lot about adding stock lockers to a non-locked 80. I've found a 1993 80 with lockers in my local p&p. Will everything swap to my 1995? Specifically, I think my 80 has a FF rear, the 93 doesn't. The PS side rear axle is different for locked 80's, so what about the axle from the '93, will it fit my '95? Thanks:cheers:Ned
Lockers came only on FF axles. Are you sure this 93 has them?
The seller could very well have mistaken his CDL button as "lockers".
search some more.
I've seen the truck; it has lockers. It's high and dry in a junkyard. I guess if they only came with FF axls, then I'm OK. Now, I'll see if I want to tackle the project! Thanks,:cheers:Ned
Rear disc brakes = FF. Some 93's only had SF/drums.
At any rate, the axle should bolt right in. Several members with earlier 80s (91-92) have swapped in FF rears.
Let us know how it goes! :bounce:
The questions are, how long is the truck sitting in the junkyard? How many miles on the truck? Are the locker actuators clean or corroded? Are the axles straight or bent? Before you tackle this project make sure to check those axles real good.
If the case that the 3rd member it's clean and well working but the actuator corroed or simpli bad .. not function, how much $$$ are asosiated to convert it to a manual locking ?
You are going to have a serious project on your hands. 14 Hours of labor for the install.
Make sure you look into the locker wire harness issue, if you are going to make your own, then I would assume that you have it covered and it won't be an issue.
