Adding padding to front seat bottoms?
Leesport, PA
I read awhile back that someone added padding to lower front seats in his 62. My front seats are not in bad shape, the leather is pretty good, and I'm lucky to have non power seats. I can't find a definitive answer as to if other seats, say out of a Volvo (best seats IMO) would fit the 80. Apparently they can be made to fit but they have to sit way higher than stock.
So, I'm kicking around trying to pull off the leather on the front seat bottoms and adding some padding. Any drive over an hour is torture on the arse. I know Nay had a shop do his for $200 a seat. Not bad but I would like to try this myself, unless I'm presuaded that it's a really hard job.
I know I will need hog rings, hog ring pliers, and some silicon spray. ANy idea on where to get good rings and pliers? What type of silicon spray is best to use?
I would need to choose what kind of foam to add and where. I think my choices would be closed cell (what is probably in there now), closed cell (think sleeping bag mat), or memory foam. I believe the person who did the 62 used memory foam. I would think it would compress too easily though and wouldn't offer support. I am leaning towards closed cell with maybe 1" of memory foam as the very top layer. If I Iused all closed cell it would probably make it easier to pull the leather cover back on though.
Should I install the foam only in the middle portion of the lower seat, or add some to the bolsters as well? Thoughts on this project would be greatly appreciated.
I installed new OE seat foam when I replaced my leather last month...huge difference. Very comfy now.
Did you just install the seat foam for the bottoms (part that you sit on), or the seat backs as well? How much $$ were they and where did you get them from? I remember reading they are like $145 a piece and are very rare to come by.
That was likely my seat thread that you read. $200 a seat isn't unreasonable given the labor involved but that's what 80-90% of that price is - labor. This is not a hard process at all, just somewhat time consuming.
I used closed cell 1/4" foam (what the foam shop called closed cell but not like my sleeping pads for backpacking, which, in comparison, are more "closed" and slick feeling). Closed cell will be more expensive than open cell but the foam shop I used thought that either would be fine.
You can get hog rings and hog ring pliers from Eastwood: www.eastwoodco.com. Probably also from McMaster but I haven't checked there for sure. I used Eastwood's angled version. My only complaint is that the rubber covers on the handles pulls off but it's not like these are expensive.
You'll also need some foam glue. I bought mine at Home Depot - it specifically said for foam.
As to adding foam to the bolsters - I'd probably go ahead and assume that you'll want to but you'll probably be able to get a better idea once the cover is off. For my seat backs I had planned on just doing the lumbar region but once the cover was off I ended up doing the whole seat back, including two layers in some places on the bolsters where the frame had worn through the foam (for my seat bottoms I used aftermarket molded foam from SOR so this wasn't an issue for me).
What kind of seat covers do you have? I had considered going this route as well, get some decent looking and functioning seat covers and put some foam underneath.. sure would be a lot easier.
It is so worth paying to have this done right. I have some hog ring pliers and hog rings still sitting in my toolbox.
Some jobs are worth the savings. This, IMO, isn't one of them, because if you don't get it right you'll be doing it again, which is a second full day of bloody knuckles and cursing.
:banana:
but
:beer::beer::beer::beer::beer::beer:
That was my newer FJ62. I used 1" thick memoryfoam (cut from oversized mattress pad). It gives good support. I did not do the bolsters, as the seat's OEM bolsters were in oood shape. You WOULD get more resistance while pulling the leather back over any foam on the bolsters, which I think would tend to pull the foam back from the edge & away from the bolster.
We rode on that seat for ~ 3 yrs. No sign of foam failing. I could tell it was slightly stuffed vs. the passenger seat (my side). You had to look hard to notice the difference; had we kept the 62 I would have repeated the job.
I was dealing with 2 seats, swapping passenger upholstery to driver's seat. So I added the foam while I had the upholstery off.
IF I were to do it again, I'd try 1.5 or 2", whatever the upholstery would accommodate w/out straining seams or looking OVERSTUFFED.
I haven't tried this with leather, YMMV. You'd want to replace the leather in a warm area, so it's more pliable.
I would rate it :banana:, particularly IF you take pics during disassembly to know where any hardware came from. I have seen FJ62 seat bottom foam which had split the bolster over subframe. What to do in that case is a possible complication.
