Warning: boring long story to ensue, skip for cliffs
Bought my first LC about two years ago, very clean but unlocked and SF rear. Read here it was easier to add lockers then to find one with, dont know who said that gem.
So here I am two years later with a pretty well rounded setup, 4in lift, 36's, Aussie locker in rear, bumpers etc. As trails become harder, I decided this setup just needed a front locker. To me price and durability is the paramount determining factor, don't care if its how it came from toyota so I don;t want to hear none of that jazz. Found a locked 94 with blown motor off mud,
, so i trailered it home with high hopes of an axle transplant into mine.
Now I've rethinking my plan of swapping both F&R axles. Recently there has been lots of threads or ive just been finding them, about the common rear axle failures with hard wheeling and large tires. Slee's old adage "if you plan on wheeling hard, go ARB's" and Ricks looking into a whole new design change of locker design has me doubting the strength of the rear with my setup being a minimum of 36" tires and 4.56 gears.
My though bprocess is if i go through all the hassle of swapping an axle and rebuilding it, the last thing i want is for it to break first time out. Even if it last a couple times, why not go with a stronger setup , possibly cheaper also. My thought is for a FF non-locked rear axle and a full carrier detroit locker. How does a detroit in the rear compare to the aussie? Honestly it does not bother me at all like some people who say it affects driving characteristics.
Also will adding a front locking axle only without the rear, will the factory wiring equipment be functional. Or does it check for signal from the rear to engage the front?
thoughts?
thoughts?
