- Joined
- Sep 17, 2005
- Threads
- 110
- Messages
- 638
- Location
- Vancouver, Canada
- Website
- www.jjadventuretours.com
Yes I know about pushing down the accelerator then pulling and tightening the throttle. That doesnt seem to help though. Before the pump was R/R the throttle worked perfectly. I was told though that without the ACSD the idle will be lower when cold so that must have something to do with the hand throttle not being able to idle the engine up enough. Also, when the engine is warm the hand throttle works fine or at least far better than when the engine is cold. So it has to have something to do with the ACSD being removed.
The hand throttle doesn't do anything that stepping on the accelerator won't do, since they connect to the same place. If you can step on the accelerator and get whatever rpm you want, then the hand throttle issue has nothing to do with the ascd. Likely your hand throttle isn't locking properly. Mine doesn't really lock anymore either.
