In my attempt to change my front rotor this morning I accidentally took apart the front caliper by removing the four smaller bolts instead of the 2 large ones.
Is there any problem with putting them back in and going on my way? I saved the washer around the brake fluid window. With as cheap as the remanufactured ones are, should I just replace it? Is there any problem with two different calipers on the front if I replaced this one and kept the original?
Thanks.
Thanks.
