1990 JDM FJ80 - 3FE. Has front and rear AC along with a cooler center console. 63,000 KMs.
So I filled (using COLD12, an R290/R600 blend - I'm not going to attempt to buy R12 in Japan) my AC two months ago and it leaked out within a week. I went ahead and ordered O-rings, a drier and expansion valve. I replaced all of the O-rings and the compressor ring. When I had the evaporator out, it had oil on the bottom of it, so I went ahead and replaced it as well. I did a visual inspection of the evaporator, the center console cooler evaporator and the rear evaporator. No oil present; though that doesn't mean they aren't leaking. I filled it back up and it worked well for a week. After two weeks, the low side pressure went from 50 psi to 10 psi at 70* (I followed the COLD12 instructions for amount needed to fill my system). The front and rear AC now blows cool, not cold.
While driving yesterday with the front AC is on, the cooler's ice maker tray frosted over even though the switch for it is off. As far as I can tell, there isn't any type of valve that would turn off flow to the console's evaporator. There is an expansion valve. With the front AC on, the compressor is running. I am assuming the center console is getting cold because gas is running through it.
My question is, if the system is at 10 psi and the front and rear AC aren't blowing cold, why is the console cooler frosting over?? I am guessing that there is enough gas in the system to make that small evaporator cold? Could this be a bad expansion valve on the cooler be causing this?
Does anyone else with a center console cooler know if it should be cold when the switch is off but the front AC is on?
I suspect my original compressor might be leaking. It has some oil on it. Next step as of now is to rebuild it (new seals) or replace it.
