AC System + Headlamp/Brake Lights
Central NC
Is there anyplace the electrical components of these systems cross???
Shop replaced AC system (compressor/drier etc.), and now I have no running lights and my brake lights don't work.
odd....
Yep, but it's major weirdness...Headlamps on, brake lights on full-time (all three), no rear running lights
Headlights off, brake lights work
Headlights off, applying the brake also turns on instrument lighting and dims the radio lighting (all OEM)
Odd issues like that are most often ground-related. I suppose the AC shop could have removed an electrical ground while doing their thing and neglected to bolt it back up when finished.
There are several ground wire clusters that bolt to the body near where the AC lines run - I'd follow the AC lines and look for/check the grounds.
Well All i can say is I lost one leg of my fusible link on my 60 everything worked but the headlights. try finding that out at the la airport. Made for a fun ride home.Like Bryson said check all your grounds.or follow the ac lines and see if they pulled a ground or something.
Take it back?
Certainly sounds like a ground issue. Anytime you see really bazaar electrical issues, its usually a faulty ground or sometimes power back feeding another circuit (broken wires rubbing together, etc).
