AC Recharge - Sounds Controversial
Well I have got a 93 Cruiser :cheers:-- air works but could be stronger:crybaby:. Has the R-12 in it and when the compressor comes on the inspection window has bubbles for a short period of time. I assume that I need an R-12 recharge. Don't know how expensive it is to have somebody work on it. Then I found the below thread and found the conversion to 134 discussion:
https://forum.ih8mud.com/80-series-tech/158096-c-not-kool-enough.html
Discussions sounded controversial so I went out online. They were just as controversial. I found the below procedure. Don't know how valuable it is but I think the important thing is not to "mix" the R-12 oil with 134 freon. I don't think that point came across in the above thread but there seems to be plenty of opinions and various levels of experience with success and failure. Just wanting some clarification since the 134 seems a little more tricky understanding when "full" has been achieved w/o all the proper equipment.
Here it is and maybe it is helpful and generate some discussion. I found it on:
Convert your automotive air conditioner from R-12 to R-134 Refrigerant. by Cooper Red Hill Supply - Online Air Tools
Jon E from Prescott, Arizona: (223 days 4 hours ago.)
Once your system is leak tight, contains the proper oil to match the refrigerant to be used, has been evacutated to remove any air and moisture contianed therein, and has a metering device designed for the refrigerant to be used, then one may charge the system thusly:
1. Attach the refrigerant container to the low (suction) side of the system.
2. Open the refrigerant container, thereby breaking the vacuum, and allow as much refrigerant to tenter the system as will go into the static system. Then, shut off the valve to isolate the refrigerant container.
3. Place a floor fan in front of the car so that air is directed against the condenser (located in fornt of or is part of the radiator) to simulate ram air (the air flow generated by a car's movement).
4. Start the car and adjust engine speed (weight on foot feed?) to approximate approximately 40 mph.
5. Place an accurate AC type thermometer in an air discharge duct which has the best air flow.
6. Turn on the AC.
7. Open all the car windows. (Note that the car needs to be in a warm environment of around 90 degrees f for charging to work best and most accurately.) This keeps the heat load on the evaporator (cold coil in the car).
8. Check the thermometer continuously.
9. As refrigerant is added, the temperature will come down for so long as the evaporator is not completely full of refrigerant.
10. Go easy, adding a little bit of refrigerant and waiting upon the system to equillibrate.
11. If the temperature drops, add a little more refrigerant and wait and watch for drop or not.
12. As soon as you notice that the addition of refrigerant has not caused any temperature drop, you have the system charged to the point where the evaporator is maximally used. STOP adding refrigerant at this time.
13. Dismantle your setup and you are ready to drive a car with a properly charged system.
This works with any refrigerant.
Note that R-12 could be charged as either vapor or liquid, with the caveat of not slugging the compressor valves with liquid. R-134a and other azeotropic refrigerants separate in the gaseous state and must be charged as liquid. Their cans are designed with dip tubes so that liquid comes out when the can is upright, just opposite of R-12 cans. Again, don't slug the compressor. That requires metering the liquid through a small oriface, which are available as individual divices, or by cracking the container or gauge-set valve and thereby causing the liquid to flash into vapor before entering the system.
I am not an auto mechanic, but an old retired HVAC tech who understands the physics and has charged all my autos thusly and those of my friends. Prior to this method, I tried all the other methods, such as, sight glass, pressures, and weighing it in. No method worked better or as well as this method.
As for converting a system, I beleive (as best as I can remember) that the oil and the meteing device should be changed when going from 12 to 134a. All systems should be vacuumed, although smaller systems used to be "blown out" with the refrigerant by many techs. All other considerations aside, that practice absolutely is illegal today.
If a system is empty when you start working on it, it needn't be recovered, but if any refrigerant is in it it must by law be recovered and properly disposed of, as must the old oil. Also, for residential and commercial systems, you by law must hold an EPA certification to open a system. I believe there is an automotive certification, but I am not certain if it must be held to work on automotive systems.
R12 is colder!
If you can still buy R12 - I would pay for it - we can't get it here in Australia - it's ilegal :(
R12 can still be had but it is very expensive and a lot of shops are not doing it anymore because of cost and the pain it is to recover. R34 conversions are not that expensive and you can do recharges yourself with off the shelf kits. The R12 does blow colder but it is hard to get. I want to switch over all of my older vehicles so I can do the work myself.
Here we go again...
1) Takes an hour or two online to legally certify yourself to buy/use r12.
2) Once you're certified, it's available from several sources. There is no shortage of it. I buy from a certain ebay store; prices are currently about $30 "buy it now". (You decide whether you think that's "very expensive"; I don't.)
Like you said, I'd much rather do the work myself. That does NOT mean you have to give up on r12.
Curtis
Thanks guys -- will check it out
Of course today, it is 11 degrees outside but I want to prepare for the Washington desert 100+ degree days this summer.
Looks like a great deal at the moment. (12min till end of auction.)
Sold for $91 (six cans). That's about half of retail.
Oh, and for anyone looking to purchase in the near future, r12 prices *really* fluctuate seasonally. No way would those six cans have sold that cheaply in the middle of summer.
Curtis
I may not be driving her this summer --- I was a dummy, dummy, dummy and screwed something up royaly while trying to "clean" my engine and peripherals. See thread -- was real excited... now just depressed:whoops:
If you're only seeing bubbles when the compressor kicks in and it runs clear in the sight glass for the rest of the cycle, then you're probably not low on gas.
I had checked the EBAY auction but it was already over --- will keep checking.
Jonheld -- Just a few bubbles when the compressor kicks in -- this is good news then.
I can't tell how effective the air conditioning is now due to the cold outside temperatures. The PO thought the air wasn't as cool as it used to be.
I will also look at the radiator fins to see if they need cleaning.
Curtis
Dang, whats retail? I've got about 10lbs left in a tank.
