AC Fixed! New Expansion Valve
Colorado
A while ago Mud helped me diagnose a bad expansion valve, and I just replaced it along with the dryer, because you should whenever you open the AC system. I had a local Goodyear shop recharge it, and now it is icy cold!
I had the shop do it because at $95 it was less than buying the tools. Replacing the expansion valve was much easier than I expected. I'm 6'3" and I never felt like I was lacking space to work. The dryer was easy. Just pull the marker light and then use a 10mm to undo the bracket, and a deep 10 mm is just right for the coolant lines.
There's a great write up here about how to do it. If you're on the fence about doing it yourself, just do it. It's easy!
It would blow cold for a little while then run hot like the AC was off, but the compressor was still spinning. The system had a good charge, but the lines to and from the condenser were warm.
How many miles?
Mine works great 95% of the time but every once in a while it starts blowing warm for no particular reason. The expansion valve is somewhere on my list of suspicions.
