AC Cools then Stops Cooling
Im not sure if a 91 had it but I had a temperature sensor go bad on mine that stopped the AC from working. Iforget what it was caled but its on the drivers side of the block under the intake. Its meant to shut the AC down if the motor begins to oveeheat.
I believe I need one of theses on my '97. Does anyone know part number, or what it's called ?? Thank you
Just to confirm , I am needing to replace the sensor that is making my AC stop blowing cold at higher engine temperatures, this
👇👇is said part ??
88790-60050 is the switch that cuts off power to the A/C compressor clutch when the engine coolant reaches 226 degrees F. It restores power to the compressor clutch when the coolant temperature drops back down to 217 degrees F.
Thank you very much !!
