Thank you guys, I will NOT buy the 92 compressor then. This is exactly the kind of info I was looking for. Thank you all...
OK next question... I have seen in searches, that you never know what exactly is wrong with the compressor. I hear some say that it could be the clutch or compressor bearing (isnt it the compressor clutch bearing?) and that it can be repaired. I then hear it might just be the compressor which would mean a replacement compressor. I am confused how you tell how bad it really is. If I can just replace the clutch and bearings and the gaskets then I will.
To explain my situation, our A/C works very well, nice and cold. The compressor (not the tensioner as I already changed the bearings only a couple of months ago and also checked with a dowell) makes a low growl noise all the time no matter if the clutch is engaged or not. Does this point to any peticular direction? Sorry for the long winded questions, but this is kind of confusing compaired to a birth repack.....
