AC compressor not cycling off automatically
Kamloops, BC
Website
www.forgottenbc.ca
Hello all
I FINALLY got my AC compressor back in the engine bay after doing my York project. It involved having the low side service port cut off the top plate and a new one from another donor hose welded onto the hard line of the low side hose.
It's working great... blowing cold. I replaced the dryer, put a vacuum overnight at -20 units of vacuum (which held fine) and replaced as many O rings in the system as I could find with new ones, including the top plate on the compressor.
While AC is on it's highest setting and windows open, my gauges show 36 (low side) and around 170 (high side). This is R12a running in an originally R12 system.
It doesn't seem to cycle off though. With my windows closed and the temperature set to something reasonably easy to obtain, such as 25 degrees, the compressor just keeps running. The only way the clutch dis-engages is if I press the AC button on the dash off.
It IS 30+ degrees C here this weekend, so I thought that might have something to do with it. I took it for a drive through town today for an hour +, doing 60km/h etc and idling in parking lots... it would not cycle off.
Bad pressure switch? Bad... AC amplifier brain? Bad temp sensor? Thoughts?
Just a few ideas: It's my understanding that the thermistor determines the lowest temperature that the compressor turns off. It has two wires going to it and if both wires are shorted together the compressor will not shut off. I have seen bad thermistors where the compressor will not turn on. I have not seen one that the compressor will not turn off though. Maybe someone else will comment. Is the thermistor installed into the fins of the evaporator? There is also a relay (of some sorts) that turns on and off under the glove box that may be stuck in the closed position.
Could be a thermistor issue. It is installed on a plastic holder that inserts into the fins of the evaporator. Your operating pressures look great. Is your evaporator freezing up? If it does then the low pressure switch will cycle the compressor off until the low side pressure reaches a value I am unfamiliar with. I would say run it until you notice the evaporator icing up. If that occurs then you should troubleshoot the thermistor.
Only ran the truck yesterday, but, so far it hasn't frozen up. Sign of that happening would be what, lack of airflow from the vents?
Only oddity I experienced yesterday (other than obviously the compressor not cycling) is that after a while, at idle, the ac wasn't quite as cold. After driving 60 down the road for less than 30 secs though it was back to nice and biting cold.
What's the duty cycle on these compressors? Is it dangerous to have them running constantly?
How do I get to the thermistor and any idea how to check it's operation and wiring? I checked the fsm but didn't see anything on it. Obviously missed it and need to check again.
Thx for the help!
Ok, I feel a little silly. Pressed the AUTO button on my climate control on the way to work this morning, and guess what... it's cycling like normal. Does it really not cycle at all when the climate control is not in auto mode?
