AC Compressor noise
Berks County PA
I have searcholder threads and found partial answers, so I am posting where I am at with an AC issue. '97 if that makes a difference. AC blows ice cold. Sometimes when I come to a stop Like at a light, after afew seconds I get a horrible sound almost like a really bad valve tap. I shut the AC off and it immediately stops. Start to drive, flip the switch AC is all good again. Another stop light same symptoms. Is the compressor still OK? What parts do I need and where to get them. OEM or aftermarket for this job. Thanks
Checked it out. It is definitely the ac compressor pulley. I can see it has a wobble. Does that mean compressor is toast too due to wobble or can't know until I remove the pulley? Thank you.
To prevent any more damage is the quick fix to just remove the belt before compressor failure? Just have no ac and it is still drivable correct?
up until last week, had this same noise for the last three years. ac worked well just made the noise you described. as stated above the pulley bearing had gone bad and last week the compressor finally went out. not my daily driver so im sure that contributed with it lasting so long. new compressor going in as of the other day. went with a denso unit.
