AC Blown?
I checked my low pressure side of my AC last night to see if it was low because the AC was not really cold. The gauge read in the middle of low with the motor running and AC cranked. So I started adding 134a and I got to just above the low limit of normal and added a little more. That just before I was going to turn the motor off I heard a click and the motor started a higher idle, and the gauge level dropped to empty. Now it won't fill at all. What might have happened?
Thanks
Except for the "won't fill at all" bit, it sounds like the compressor wasn't engaged due to low refr. level, and then finally kicked in when you got a bit in there.
You say you had the A/C "cranked", but if it wasn't at high idle, are you sure the compressor was engaged?
Curtis
AC Cranked meaning it was on in the truck. The compressor didn't kick on until I had got to the low limit of normal. Then it kicked on the RPM went up and the AC Pressure Level dropped to 0.
x2
The reason the gauge went to zero (I assume this is one of those gauges that comes with the refrigerant...get a real set of gauges if you're going to mess around with the AC) is that as the compressor cycled on after reaching the low pressure limit, the suction side of the compressor pulled a vacuum on the system (which it's supposed to do), giving you the low/zero pressure. What you need is more refrigerant in the system, however, I would not trust that gauge you have, and unless you've done something you didn't mention, you have not solved the problem of your leak.
i blew the front seal on my compressor with one of those cheap gauges. It keep indicating i needed more freon. you really need to know what the high side is doing also.
Now you scared me. How much was that to fix?
mine blew, it poped and i watched all the freon leak out.. a new compressor from ebay "TechChoiceParts" $165.00, a new line dryer and some o-rings $50.00. I also decided to replace the expansion valve $60.00 since i was going to open up the system. And since i was going to do the work myself i also picked up a set of real r134a gauges $80.00, a vaccum pump $150. and 4 cans of r134a $36.00. took about 4 hours.
10 months later still working like a charm.
Ouch!
not that bad overall, I figure i came out good. The OUCH was the almost $1,600.00 for the dealer to do it. the factory compressor alone is almost a grand.
