ABS, VSC Trac, VSC Off, Brake Lights on with ABS alarm.
No! I've been messing with power steering rack bushings. Just finished them this morning...near impossible but I did get the new ones in. I did check all of the ABS sensors (front and back) while trying to keep my sanity. Thought I'd try a task I really could do. I did buy an ABS ECU on eBay and at some time I will try that to see. Will let you know.
I just took apart abs electric motor. I will try to rebuild it. I think thats the problem
Did some searching on this forum and came across several similar issue I encountered. Here's mine and what the prognosis is...For the past week, I had the ABS, VSC TRAC, VSC OFF and BRAKE lights along with the continuous beep come on as soon as I started the engine. It would only happen once or twice a day (not everyday though) and only last about 10 seconds and it would turn off. Never while driving. No issue with braking after the light/sound went off.
So, I got myself a $100 BlueDriver Bluetooth OBDII reader to get a scan on the issue. Never used one in my life and it was actually really simple to use and was able to pull couple codes..C1223 (ABS Control System Malfunction) and C1251(Pump Motor Circuit Malfunction). Hoping it was a simple issue, I did some things you guys have recommended trying:
1) Did the 40 brake pump to check the level and motor (it was fine)
2) Cleaned all 4 ABS sensors. I was lucky that it wasn't stuck and it was a simple task and didn't have to take off any wheels (It was dirty)
3) Checked the battery and for low voltage (it was fine)
4) Checked for brake fluid leaks at caliper/wheel area (no leak)
5) Clear codes and see if it comes back (it did come back)
At the end, the codes came back and the lights and beeps were still there. So, not to take anymore risk, I took it in to my independent shop in San Diego. They used the techstream and pulled the codes and they visually checked the master cylinder unit. They confirmed its the MC and showed some leak.
So, my 2001LC with 172K is getting a new MC assembly and control module as we speak. So, I guess I should be set for another 175K miles! Didn't want to deal with another problem with ABS so I didn't take any risk with used assembly or control module. The price is definitely steep and a bit depressing. This is the most expensive fix I have done to this LC. Still in a bit of a shock.
How much was it to replace the MC? And was it really necessary? I’m having the same issue with my 2000 Lexus LX 470. I just recently got my vehicle lifted about 2.5 inches and had to disconnect the ACH for the lift. The beeping sound is so annoying and it has me concerned .
Thanks for the input. Let me know what you find. The car runs so I'm not worried but sure would like to find what the issue or issues are.
2000 Land Cruiser with all the warning lights on...TRAC, ABS, Brake, etc but no beeping. Tried to troubleshoot with OBD but says it can't connect with control module. Checked wheel sensors and all good. Been driving can for 5 months now and except for the warning lights, everything is normal. Thinking of getting an MC, ABS,etc unit for whenever I do have a "real" failure. Car has 174,000 miles on it so not unheard of to have brake deterioration. Have been searching for a month now to find correct part number but no luck. I get different numbers from different source (Toyota part) they all say the part will fit. Anyone out there know the real part number? Where on the unit would the part number be?
