ABS Pump won't turn off
All,
My ABS pump won't shut off (humming/buzzing/vibrating) even when the truck is not running. I have to pull the fuse to get it to stop. The ABS light is on the dash as well. I haven't pulled codes yet, but I'm wondering if anyone has seen this before and knows what is going on/the fix for it.
Cheers,
J
Is the ABS light illuminated in the dash? If not, there may not be any codes stored. Pulling ABS codes is different than engine codes. You'll need to jump from E1 to Tc and remove the short pin in the corner. Don't lose this shorting pin. Key on, engine not running.
There is a relay near the ABS unit that may have failed with the contacts welded or stuck.
The ABS light is on solid so I'm guessing it is throwing codes. When jump E1 to TC and remove the short pin, once this is done, do you pull the codes as normal through the OBD port?
Also, what is the best way to test the relay?
Cheers,
J
You count light flashes. The FSM shows how to do this under Brakes.
I wouldn't test the relay until you know what the problem is.
I get code 14. From what I can tell this is a short in the motor relay circuit. I'll check the connections and wiring. Please let me know what else to look for and how to test the relay.
Regards,
J
Pull the relay and put the rest of the system back to normal. Fuse in, jumpers back to normal.
Turn on the key. If the pump runs, it probably wasn't the relay or associated circuit. If the pump doesn't run, you should then check for welded contacts.
The easiest way will be to put the relay back in, turn it on. If the motor runs, whack the relay with a screwdriver handle. If the motor stops, replace the relay with a new one. If the motor keeps running, it could be welded stuck still, but try it and post your results back here.
Mine had an issue the other way. My relay wouldn't close. I tapped it with a screwdriver and it has worked since. I think mine was simply dirty contacts in the relay socket
Thx blkprj80! The Ole BFH (or gentle use of the blunt end of a screwdriver) worked perfectly on the relay. We'll see how long it lasts, but glad not to have to mess with it at the moment.
I owe you a couple frosty beverages!!
Cheers,
J
Sweet! Glad it worked for you!!
Yeah, sometimes you have to resort to ferd techniques.
I suggest you pull that relay and check the socket with a bright light and magnification. Also check the pins on the bottom of the relay. I don't expect you to find anything since your relay was stuck on though.
Did you happen to activate the ABS recently? I usually try to lock mine up on ice, just to get some fresh brake fluid flowing around through there.
