ABS LSPV Removal Question.
North Front Range, CO
When removing the ABS module and LSPV do you hook up the front lines to the front of the master cylinder and the rear lines to the rear of the master cylinder. This is still using the ABS master cylinder.
It's opposite of that pic.
Look up jcardona(s) abs delete thread or my thread. Pretty clear in both. You also don't really need any flare tool. Just need a premade 2@12" section and one coupler, and the one reused T. All are metric m10 x1.0 inverted flare.
I saw the opposite way of hooking up lines but it was with a non ABS master cylinder so I thought I better ask.
What through me was the sensing line that runs off the tee under mc. The sensing line runs from the tee to the LSPV (or back to the rear brakes if you didn't know it was just a sensing valve) off the front brakes.
I have them hooked up backwards. It brakes fine this way though.
If the brakes are 50/50 now, what would it matter if if was hooked up either way?
Closest to booster is usually front brakes. If you follow oem routing on lines it's self explanatory.
Likely your one of your rear e brake shoes is hanging up the cable. Brake light and ABS light are not connected
After removing the ABS the BRAKE light is on now? I already removed the ABS bulb but why would the BRAKE light be on now?
Or fluid low
Its weird, the light came on at same time as when I removed the ABS system.
I will check e-brake.
Fluid is full. I think maybe the sensor in the master cylinder is the problem, I did suck out all the fluid before working in brakes. Is it a float or other type of sensor?
Its a sticky float. When you pull the e-brake, the BRAKE light gets brighter.
I have the reservoir off the master cylinder and the float is sticky. Not sure what I could stick in the free up the float???
Bypass it. its dumb.
