ABS light staying on???
North Cadillac
This is after i did the following:
*removed the front swaybar
*took slee's caster plates off and replaced the front bushings with his 3degree bushings.
I know i was VERY careful when taking the sway bar off the truck to un-clip the ABS lines off it before i removed the bar. I was also super careful not to tugg on it or cut it. I have also gotten under the truck and examined the front two sensors to make sure they are fully plugged in. They are. I also examined the cable as close as i could to make sure i didn't cut or gouge it. It appears to be just fine.
I did have the CDL button locked because i had the front driveshaft out. Now the shaft is back in, i pushed the button, CD light went out but ABS stayed on :confused:
What the heck did i do? :censor:
Have you driven it at all? It might fix itself.
-Spike
Pull the ABS fuse (yellow one in the engine bay fuse box) and disconnect battery.
Have a beer.
Put fuse back in and reconnect battery.
how about 2:beer::beer::D
I will give that a shot tomorrow.
So far i have driven about 3 days and several hundred miles and it's still on. :mad:
So i have tried the suggestion above and it didn't work.
So then i pulled the two front sensors out and checked them for debris. Nothin'. The Amsoil Moly still looked like new in there.
I haven't pulled the rear's yet.
Can i use a diagnostic scanner for it to tell me which sensor is bad? I'm thinking there is a rolled doner vehicle just up the road. I need to get up there and get a sensor before it's gone if i need one.
On my 97 a friend that understands diagnostics way better than me (and is a Toy Master Tech) jumpered two terminals (don't know which) in the Diagnositic port in the engine bay and the ABS light flashed the issue code. Mine was a rear sensor, cleaned it off, all was good.
Thanks Cory. I was thinking i remember reading way back that someone plugged their scangauge in and it told them which sensor was bad. Just looking to see if that's correct. I don't have a scangauge, but figured somewhere i could find some kinda plug in reader.
