ABS Light on
Whats the deal? How do I check it? Can I get it checked? How severe is this?
Probably gunked up sensors in the steering knuckles or in the rear sensors.
Take each sensor out and clean the magnetic ends off. There will probably be tons of moly and metal shavings on the end of it. Clean them off at all 4 sensors and make sure the wiring is kosher while you are at it as well.
Then, disconnect negative terminal from battery, have a beer, and then put it back on and see if your light goes on.
Are you getting any feedback from the brake pedal? Any anomalies that you were not aware of earlier?
I hate friggin' ABS. I cut all the wires and that took care of that.
:grinpimp:
Nothing weird. Before I changed all the bulbs in my dash I didnt have it and It would come on when ABS activated. It came on about a month before the bulb change. But hwere are these sensors located?
For the the front, there are two sensors that go into the top of the knuckles. They have wires going into them and they stick out about 1.5 inches from the knuckle. They have a rubber boot on them and underneath the rubber boot they have a male-female connection. They are held down by 2 12mm bolts that bolt into the knuckle housing.
The ones on the rear are basically the same type of sensor only they go into the hub housing from the rear of the axle. Again, wires, rubber boot and male-female connection.
I did a FAQ on cleaning the fronts, the rears are almost identical, but no grease. Cleaning them is very easy, just don't stretch/break the wires. If you want to be sure that's what it is, take a 6 pack of :beer: in to your local dealer and find a tech. He can use a jumper on the OBD sensor in the engine bay that will flash a code on the dash. The code will tell you which sensor (or whatever else) is the problem.
In my case it was my DS rear, lots of metal on the end. Wiped it off, put it back, no more light.
