ABS light. Help!
Dallas TX
I’m going crazy trying to get this ABS light sorted.
I jumpered TC E1 and got error code 31.
ohm’d wire to right front and found it to be open.
Replaced the wire and thought it would be sorted.
Now suddenly the ABS light won’t go off at all.
With battery disconnected overnight
With the jumper and hitting pedal 8 times
Etc.
now it just stays on permanent. Can’t get it to clear codes or flash any error codes.
Any suggestions what to try next? (Besides removing the bulb) I have the FSM and the wiring supplement. But can’t find anything else to try.
Well, you've proved the system error checking works...
Nvm I’m an idiot. I figured it out. How can I delete this? 😂
Send a PM to an administrator/moderator asking to delete your post and explain why.
Just leave it; who knows, it may help someone later.
