- Joined
- Jul 5, 2010
- Threads
- 13
- Messages
- 310
My dad has owned an '07 FJ Cruiser since new, and his ABS just went out. As he was driving a warning beep came on, accompanied by the BRAKE and ABS lights on the dash. He was able to pull over and stop. But when he restarted his truck he had very little brakes. He had it towed to the dealer and they told him it was the ABS Pump Actuator, and they wanted $2100 to replace it.
Looking on Mud, I see several ABS pump failures in the 100 Series forum, but essentially nothing in the FJ Cruiser forum. Is this a common problem? Is there maybe a sensor failure that could be causing the ABS module to shut down? If it likely is the ABS pump actuator, how hard is it to replace, and is there a non-Toyota equivalent that would be better to buy?
A couple other things worth mentioning: He has had an A-TRAC switch installed since early on, but it did not come with that option. He has been concerned about a buzzing noise that can be heard from outside of the vehicle while it is running, but the dealer has said it is normal and has to do with the brake system pressurizing itself.
Any help is appreciated. I can even add some pics of his cruiser or some sweet pics of remote places in UT/AZ/NV he has visited in it to this thread if it helps.
UPDATE:
This seems to be the buzzing noise my dad has been hearing since day one. I don't think it's related to his ABS problems, though.
UPDATE:
