ABS codes - can you help?
Texas!
Website
www.youtube.com
Guys, I can't find my e-copy of my 80S manuals... can someone look up the ABS codes 11, 33, & 35?
That is what I'm getting when I do the TC-E1 jumper trick and watch my ABS light. Came on this morning and I had low brake fluid (just below min) which is another concern I'll deal with. Added brake fluid back up to max, ABS is still on. Got those codes. Want to know what they are before I just reset the ABS light.
Thanks in advance!
Alright a little update on this situation. The only code I read now with the brake reservoir re-filled is 35. I'm getting a code 35 when I jumper the pins on my Diag port per the instructions I found on this forum. It blinks a 35 which is " Foreign Matter on RF sensor". So I pulled that sensor this afternoon and it had some grease on it. I cleaned it off looked in the hole and could see the teeth on the sensor ring. Nothing really stood out. I ohm'd the sensor and got 1254 ohms. Anyone know if that is in spec? Put all back together. Tried to reset the code. Wouldn't go away. Drove it a little. Killed it. Started it. Same ABS light. Jumped to check code. Still 35. What do y'all think?
I am bumping this I am getting 35-36 codes and cleaned the sensors checked the OHMs and I need help
