ABS & CDL problem
orlando, fl
I swapped to Longfields and didn't use the ABS tone rings and am growing tired of looking at the ABS light on the dash. So I did a search, and decided to give the ABS fuse a pull. Well, pulled it out, and tried my CDL switch to make sure I still had the lock, nothing except for some subtle clicking noises coming from the drivers side kick panel. So I put the ABS fuse back in, still no CDL and all fuses are good. Did I destroy my relay in the kick panel? Any ideas?:bang:
The centre diff lock uses a separate fuse (30A diff lock) than the ABS (60A ABS) so I think you just have a coincidence on your hands. Did the CDL work before you pulled the ABS fuse?
Yes, everything worked fine. I have checked both fuses, they are fine too. I read on another thread that the ABS fuse when pulled will affect the CDL, so thats why I checked it. Well, on my 97, it sure does. I'm afraid I burnt up a relay in the kick panel now. I bet CDan has some kinda thought...
No idea. Time for you to dig out the EWD and start studying it.
ABS activation is seperate from the CDL (though the CDL switch does trigger it on/off).
If you did nothing else other than pull the ABS fuse, then your CDL *SHOULD* still work. The click you hear is supposed to happen, that's from the relay inside the cab. Do you hear a similar click coming from the T-Case (have someone else dis/engage the CDL switch with you outside the cab)?
You will want to start researching CDL threads, plenty of examples and troubleshooting on here including using a battery to jump it to test.
I'm familiar with all of the clicks, now theres just silence. I was really hoping somebody had a similar situation at some point and could shed some light. :bang:
