ABS brake fitting leak (???)
Missouri
Hello all,
Ive been working on deleting my LSPV and replacing with a manual wilwood proportioning valve. When I went ahead and started pressure bleeding I noticed leaking in two spots: the first was at the willwood valve itself because im an idiot and cross-threaded the fitting (new valve arrives tomorrow), and the second was one of the abs ports. I used brake lines with fittings from O'reilly's (part paj-312) and i have no idea what could be causing this spot to leak. The oreilly's fitting is a little bit longer than stock, but that wouldnt cause the issue, right? The leak is very slight and in the picture you can see a thin bead of fluid around the entrance to the port.
Any ideas?
